Laser Cut And Fill
![](https://cdn.sanity.io/images/i7cqi3ri/11/31cf48c1b7b1edb6318625f43b0170ac41b2c509-278x814.png)
The Laser Module is available as a paid-for add-on to the software. The features are not included in your software by default. To find out more about the Laser Module, please go to https://vectric.com/laser-module
Tool Selection
Select Tool
Power
Move Speed
No. Passes
Strategy
Based on the selected vector shapes in your drawing, this toolpath offers four distinct strategies.
Cut Outside / Right
Cut Inside / Left
Cut On
This option will run the center of the laser beam along the selected vector. No offsetting or kerf compensation is required.
Hatch Fill
Allowance
Stepover
Hatch Angle
Fill Together / Fill Regionally
These options will change how areas separated by spaces are treated. In the example of the word "Test" with Fill Together selected the letters will be treated as one whole space to be filled whereas with Fill Regionally each letter will be treated separately as its own individual region.
Outline
Selecting this option will then create a defined outline around a chose vector. If unchecked there may be gaps around the edges if the stepover is large enough whereas when checked an outline passing around the outside will appear.
Note:
Immediate Output
![](https://cdn.sanity.io/images/i7cqi3ri/11/e833a13a37b5f8e002e28de314e82723350e6259-255x160.png)
Post Processor
Add side to toolpath name
Output direct to machine
